The ’65 Impala is a classic and iconic muscle car that has been revered by car enthusiasts for decades. If you’re looking to take your ’65 Impala to the next level, consider building an “Impostor” version of the car. An Impostor is a custom-built ’65 Impala that has been modified to resemble a later model Impala, such as a ’69 or ’70.
Building an Impostor ’65 Impala is a challenging but rewarding project that requires a combination of mechanical skills, attention to detail, and creativity. To get started, you will need to gather all the necessary tools, parts, and materials. This may include items such as a new grille, front and rear bumpers, fenders, hood, and side trim. You will also need to obtain a set of wheels and tires that are appropriate for the Impostor look you are trying to achieve.
One of the key aspects of building an Impostor ’65 Impala is getting the bodywork right. This involves cutting and welding various parts of the car to create the desired shape and contours. You will also need to fill any gaps or seams with body filler and sand the surface to a smooth finish. Once the bodywork is complete, you can move on to the painting and detailing phase of the build.
In addition to the exterior, you may also want to consider upgrading the suspension, brakes, and engine of your ’65 Impala to improve performance and handling. This may involve installing new shocks, springs, and sway bars, as well as upgrading the brakes to disc brakes or adding a high-performance engine.
Overall, building an ’65 Impala Impostor is a rewarding and challenging project that will give you a unique and eye-catching car. With the right tools, parts, and attention to detail, you can create a one-of-a-kind Impala that will turn heads wherever you go.
